nibin Posted February 11, 2011 Report Share Posted February 11, 2011 i have a 2005 Escalade and i want to replace the daytime running lamps. can somebody tell me how can i do that Link to comment Share on other sites More sharing options...
gildi Posted February 13, 2011 Report Share Posted February 13, 2011 You must first remove the cover above the grill. Once done you need to remove the metal bars that connect the grill. That will give you access to the area where the bulb assembly is at. Twist to remove the assembly and change the bulb. Link to comment Share on other sites More sharing options...
