sawar Posted May 8, 2011 Share Posted May 8, 2011 the car is slow in response when i need to make a sudden lane change why is it happening as it wasent the case earlier. thanks Link to comment Share on other sites More sharing options...
stuart Posted May 9, 2011 Share Posted May 9, 2011 Car is loosing power, if also you have white smoke and coolant is depleting then that means you engine head gasket is leaking and you need to change it ASAP. If no white smoke and coolant level is fine, then check with spark plugs, coil and HT leads is fine or not. Link to comment Share on other sites More sharing options...
sawar Posted June 5, 2011 Author Share Posted June 5, 2011 thanks Link to comment Share on other sites More sharing options...
