VolkswagenDubai Posted August 28, 2011 Share Posted August 28, 2011 Volkswagen Scheduled Maintenance Procedures Inspect Automatic transmission shift linkage Inspect Ball joints & tie rods Inspect Battery Inspect Brake pad thickness Inspect Brake system Inspect Cooling system Inspect Drive belts Inspect Driveshaft boots Inspect Engine (check for leaks) Inspect Engine coolant level Inspect Exhaust system Inspect Fuel system Inspect Idle speed Inspect Intake air system Inspect OBD system - check for codes Inspect Power steering fluid Inspect Steering system Inspect Transmission final drive fluid level Replace Air filter Replace Brake fluid Replace Cabin air filter Replace Coolant Replace Engine oil & filter Replace Spark plugs Link to comment Share on other sites More sharing options...
