rashiddxb Posted October 11, 2013 Share Posted October 11, 2013 Hi guys, I would like to dig into one of my door panels and check the speakers and window wiring because the window will not function properly ie, will not go all the way up, plus the speakers are making this distorted noise and i feel it is coming from the same door. How can i look into this? Link to comment Share on other sites More sharing options...
ahmedobaidi Posted October 12, 2013 Share Posted October 12, 2013 Do you mean that you want to take out the door panel and check the wiring inside it? I dont know how people gather the guts to do that by themselves ... Link to comment Share on other sites More sharing options...
corpal Posted October 12, 2013 Share Posted October 12, 2013 I would only do it with a door panel removal tool otherwise its straight to the mechanics for me. Link to comment Share on other sites More sharing options...
mr.right Posted October 12, 2013 Share Posted October 12, 2013 The door panel removal needs a little caring but its not impossible nonetheless. You just need to take out the door panel in such a way that it would be easy to reinstall it when you are done. Thats all. Link to comment Share on other sites More sharing options...
baseet Posted October 12, 2013 Share Posted October 12, 2013 i had to get my windows checked once and i stayed around for the guys to do it in front of me. Seemed to be a little scary process. You need to pull out the control panel of your windows and locks from the door panel with a flat head screw driver and access some screws behind the control panel for the inside handle and screw them out. Gives you access to the wiring and other relevant things on the door. Link to comment Share on other sites More sharing options...
