Air filter replacement
Can i replace the air filter on my own or do i need to go to my dealer for the same?
Yes you can. Here is the procedure:
a. in front of radiator support, there are 2 T20 Torx fasteners. First remove that.
b. Take a screw driver and release the duct off by unscrewing retaining tabs from each side.
c. Remove the air filter by loosening the hose first. Dont forhet ro disconnect the duct from mass airflow sensor.
d.then you can replace the air filter with a new one by first removing the air filter hosing lid.
e. Re install the air filter hosing in the same structure you removed it.
This is how you replace the air filter. Just make sure that the engine is off when you are.doing this.
  • 2 weeks later...
Thanks Dude! That was really helpful. I tried cleaning it and thus there is no need to replace it. You saved me spending money for the replacement of air filter. Thanks again!
