Why more coolant!
  • 4 weeks later...
Engine overheating is a very general problem that most of the driver faces. If the coolant is at low level or leaking, it damages the complete engine and result into overheating. To stop such a risk, one needs to make sure the coolant level is properly maintained in the car. So, whenever you feel that your is getting heated, then you can directly check the coolant level. And if the coolant needs to be filled, you can refill with that time itself if you have the coolant. You don't have to wait till to take your car to the service station. By doing this, you avoid lot of problem that can damage car engine.
