Vaccum leak
Actually there are many ways to look up for vacuum leak, but the easiest way is to use the smoke machine. You can find the smoke machine in any workshop. You can buy it or rent it. Spray the smoke on the intake manifold, hoses and gaskets. You will notice smoke seeping out for the leak. Use the UV light to see the leak and you will get it.
In addition, don’t ignore even if the vacuum leak is too small to be seen from naked eyes. Any small leak can lead to the bizarre and you will pay a heavy amount for the damage and replacement.
