alikhan Posted August 25, 2014 Share Posted August 25, 2014 Can I open the radiator cap if the engine is hot/ or if the temperature light is on? Link to comment Share on other sites More sharing options...
hemesh Posted August 26, 2014 Share Posted August 26, 2014 No ways you can do that. You wanna burn your hand or something? Dont even touch it. Link to comment Share on other sites More sharing options...
edward Posted August 28, 2014 Share Posted August 28, 2014 He is right. When the engine is hot, opening the radiator cap means blowing off the complete heat which is not really good. Radiator is really hot and if you try to open the radiator cap, you may damage the complete engine system. Not only that, it may burn your skin too. Link to comment Share on other sites More sharing options...
gshane Posted April 20, 2015 Share Posted April 20, 2015 That is not something that I would recommend. Wait for few minutes or even 10-20 minutes if necessary and remove the cap. If you rmeove it before the water is cooled down you won't know how much water you have and you can burn your hands too. Link to comment Share on other sites More sharing options...
shadow79 Posted September 11, 2016 Share Posted September 11, 2016 Well you might miss a teeth or two if the cap aims at your face and scald your skin too wherever that high pressure cooked coolent falls so please don't attempt it for your safety and others near you..I've seen it happen at a nearby workshop. Link to comment Share on other sites More sharing options...
