Lanash Posted December 11, 2018 Share Posted December 11, 2018 (edited) Hi guys I just purchased 06 camry gcc spec made in australia.i want to change engine oil and transmission oil as previous owner maintained from dynatrade and I guess they are using total oil.I was wondering if I change to toyota atf type t4 transmission fluid will it damage the tranny and what oil visco do you recommend and brand.I saw lexus oil 5w40 full synthetic.is that ok to use.I have only 100kms left for next oil change.dont know which oil to use as the dubai temperature I heard it hits 45 -50degree.just confused and any recommended garage.plus any thing to consider ehile changing transmission oil shall I buy crush washer or anything else to buy etc.. Edited December 11, 2018 by Lanash Spelling mistake Link to comment Share on other sites More sharing options...
desertdude Posted December 12, 2018 Share Posted December 12, 2018 Look up what oil is recommended in the owners manual. If you don't have one you can find one online. Also not 100% sure if it was this generation of Camry but these things had a manufacturing fault where yhe engine would burn a lot of oil. I'm talking something like a liter for every 1000 kms. There was a service advisory on this where Toyota would fill up your oil seal the cap tell you to drive 500 or 1000kms and then recheck the oil and if it was burning oil they would fix tue problem for free. So look up if your Camry falls within those years Oops. A liittle looking around and it seems your Camry falls in that category. I would keep my eyes on the oil level like an eagle 1 1 Link to comment Share on other sites More sharing options...
shadow79 Posted December 12, 2018 Share Posted December 12, 2018 the atf oil is toyota t4 if you put any other oil then you are shortening the life of the transmission and the engine is 2az fe which should run fine if you put any good quality 10w40 oil but keep in mind that it's a timing chain driven engine just change it on or before time and all will be good 1 Link to comment Share on other sites More sharing options...
Lanash Posted December 16, 2018 Author Share Posted December 16, 2018 Oh ok.I put 5w40 lexus oil and used atf oil after a flush..can u pls explaing more about the burning oil issue is there any part that shoud be replaced?I am worried now. Link to comment Share on other sites More sharing options...
shadow79 Posted December 17, 2018 Share Posted December 17, 2018 Jast keep an eye on oil level stick and the place where you park overnight 1 Link to comment Share on other sites More sharing options...
