Sunit Posted April 9, 2019 Report Share Posted April 9, 2019 On a separate note, my tires were filled with Nitrogen air, do i need to fill the same again or can i fill normal air at fuel stations? Whats the ideal Air pressure (PSI) for 265/17 R16 1 Link to comment Share on other sites More sharing options...
Srikumar Posted April 9, 2019 Report Share Posted April 9, 2019 1 hour ago, Sunit said: On a separate note, my tires were filled with Nitrogen air, do i need to fill the same again or can i fill normal air at fuel stations? Yes with Nitrogen, if you intend to keep it with Nitrogen. Else it will eventually just become normal air filled tyres. Regarding the pressure it depends on the condition of your tyre. Normally for good tyres you can keep it at 35 psi, but with worn tyres and summer approaching I would suggest reducing to about 32-33 psi 4 Link to comment Share on other sites More sharing options...
Danny Posted April 9, 2019 Report Share Posted April 9, 2019 Yes you can mix and still be running on 78.08% nitrogen or maybe more in your case 2 5 Link to comment Share on other sites More sharing options...
Sunit Posted April 9, 2019 Author Report Share Posted April 9, 2019 2 hours ago, Danny said: Yes you can mix and still be running on 78.08% nitrogen or maybe more in your case Good one Danny. had a good chuckle over this. 1 Link to comment Share on other sites More sharing options...
Barry Posted April 9, 2019 Report Share Posted April 9, 2019 78% nitrogen is all you’ll ever need. I put it in tyres every day and never had a complaint. Heck, I don’t even charge for it. 2 1 Link to comment Share on other sites More sharing options...
