WiLfY Posted May 4, 2019 Share Posted May 4, 2019 2 hours ago, Fuad said: Which tyre size you are using now? There is an offer for Amada Xtreme complete suspension kit for 1800 for a pajero. Ok I'm using 275 65 r18 1 Link to comment Share on other sites More sharing options...
Fuad Posted May 5, 2019 Share Posted May 5, 2019 14 hours ago, WiLfY said: I'm using 275 65 r18 Did you ever felt you are loosing torque with that upsize? While climbing? 1 Link to comment Share on other sites More sharing options...
desertdude Posted May 5, 2019 Share Posted May 5, 2019 1 hour ago, Fuad said: Did you ever felt you are loosing torque with that upsize? While climbing? Doubt it, from what I can remember stock jero size is 265 so its only a tiny bit bigger. I went fro 255s to 75s on my Discovery without feeling much change but that could also be the LR V8 is a very torquey engine starting from very low down in the rpm range 1 Link to comment Share on other sites More sharing options...
Fuad Posted May 5, 2019 Share Posted May 5, 2019 24 minutes ago, desertdude said: Doubt it, from what I can remember stock jero size is 265 so its only a tiny bit bigger. I went fro 255s to 75s on my Discovery without feeling much change but that could also be the LR V8 is a very torquey engine starting from very low down in the rpm range Stock for 18inch is 265/60/18 this size is 275/65/18 about 124mm difference in circumference. Huge tyre 1 Link to comment Share on other sites More sharing options...
WiLfY Posted May 6, 2019 Share Posted May 6, 2019 On 5/5/2019 at 12:55 PM, Fuad said: Did you ever felt you are loosing torque with that upsize? While climbing? Have been to a few drives after the tyre change and felt no difference in torque. 1 Link to comment Share on other sites More sharing options...
Fuad Posted May 6, 2019 Share Posted May 6, 2019 4 minutes ago, WiLfY said: Have been to a few drives after the tyre change and felt no difference in torque. Then its great. Enjoy. Love to meet you n next drive.😉 2 Link to comment Share on other sites More sharing options...
Derick Posted May 8, 2019 Author Share Posted May 8, 2019 Thnax guys for helping and will try first spacer as its for 500 dhs, alo remove the black plastic under bumper 1 Link to comment Share on other sites More sharing options...
