Mark B Posted September 9, 2024 Share Posted September 9, 2024 The draw is mad 55amps but split over two fused wires, which is why you have 2 x 40amp fuses for the ARB it’s a split circus so the if one fails the other one still runs in most cases. They actually pull around 27amps each so copper 10 AWG would be fine, but 8 would definitely cover it. I went with 10 AWG but it’s only in the back seat so was around 8 feet of wire. but make sure this is based on copper not aluminium, aluminium definitely go 6 AWG 1 Link to comment Share on other sites More sharing options...
Gary F Posted September 10, 2024 Share Posted September 10, 2024 17 hours ago, Frederic said: Have a look at below chart. Considering the distance from your battery to the compressor located in the back of the open bed, you’ll need to go for 8AWG or 6AWG. I think the twin compressor draw close to 50Amps. Yep that is the exact chart I’m using , just need to find where to purchase as I need 4 runs for both compressors in our two jeeps,. Link to comment Share on other sites More sharing options...
Mark B Posted September 10, 2024 Share Posted September 10, 2024 Not sure of shops, but I find desert cart has better Availability of wire then Amazon Link to comment Share on other sites More sharing options...
Frederic Posted September 10, 2024 Share Posted September 10, 2024 1 hour ago, Gary F said: Yep that is the exact chart I’m using , just need to find where to purchase as I need 4 runs for both compressors in our two jeeps,. Ah yes each compressor has its own supply. I thought you were planning on pulling a single power supply cable. "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Marek Posted September 10, 2024 Share Posted September 10, 2024 naah... dual arb is fused with 40 Amp fuse and at 12V it should draw from 26 to 35A max. @Mark B, I have plenty of 10mm2 red&black cable left from my past installations (pure copper, not the aluminum+copper coated), and can share it. It's AWG8 if I read conversion tables correctly. Link to comment Share on other sites More sharing options...
Mark B Posted September 10, 2024 Share Posted September 10, 2024 That’s nice of you mate, it’s Gary that’s installing, Link to comment Share on other sites More sharing options...
Marek Posted September 11, 2024 Share Posted September 11, 2024 @Gary F check msg request @ insta 1 Link to comment Share on other sites More sharing options...
Stuart G Posted November 2, 2024 Share Posted November 2, 2024 Hi Everyone, I'm a Newbie; new to Dubai, new to 4*4, new to deserts, new to the club as of 10 minutes ago... in fact I don't think you could get more newbie than me I'm buying kit on the Essential Off-Road Gear list so I can sign up for drives. The list is not specific about a compressor and reviewing this thread it is a tad confusing. Looking online lots have scary online reviews about dying after a month or two. Anybody care to suggest something that would be suitable for me? Many thanks! Link to comment Share on other sites More sharing options...
Frederic Posted November 3, 2024 Share Posted November 3, 2024 19 hours ago, Stuart G said: Hi Everyone, I'm a Newbie; new to Dubai, new to 4*4, new to deserts, new to the club as of 10 minutes ago... in fact I don't think you could get more newbie than me I'm buying kit on the Essential Off-Road Gear list so I can sign up for drives. The list is not specific about a compressor and reviewing this thread it is a tad confusing. Looking online lots have scary online reviews about dying after a month or two. Anybody care to suggest something that would be suitable for me? Many thanks! 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Rare Jose Luis Campos Posted November 3, 2024 Share Posted November 3, 2024 58 minutes ago, Frederic said: All in one answer😄👌👌👌 Link to comment Share on other sites More sharing options...
