audi CV joint has sparated and need help
I get a rumbling noise when I drive and according to the mechanic the inside boot on the driver's side CV joint has separated, he has given me 2 options that is to get it replaced or repaired and i need a second opinion on this please
thanks
If you are already having a noise then the CV joint has run dry and is damaged. Most likely you would be having vibration under acceleration. So you are better off changing the drive shaft rather than fixing the boot.
I second to Iroc, boot should be completely sealed and loaded with grease so that joint wont run dry. If once boot tear and car run for a while or if you are in doubt then its better to change to save the hassle and labor cost for second time.
