Overheating Transmission, Pajero 2008-2020
Just now, jeetu sharma said:
Sorry for all the questions...but since you have fixed the fan can you recommend a garage and if cost estimate. I see AED250 from a garage in Sharjah
Can you pls whats app me on 0559323959
Chinese one is 250, Taiwan one is 500. I went in for Taiwan one, not much sound compared to Chinese one.
Last week I tried driving on automatic mode for 5 min that too around 7 AM and had overheating problem with 2 auxiliary fans running. So this is a never ending problem with pajero, need to drive only on manual mode and always 👀 pop out looking into gauges!!!!
  • Sad (0) 3
It was the fan which I install got worked sometime and doesn’t sometime as it got struck with some dirt, when that was cleared and fan running properly theres no overheating problem for the last 4 drives even on steep climbs. Pretty much relaxed now.
  • Well Done (+2) 3
Thankfully even I did not have any issues on my last drive. I used 4HLC and tiptronic. I guess the key was to ensure minimal gear shifting (I made sure I maintain 2nd gear and kept an eye on the RPM as well). Since the drive was relaxed without steep climbs (only exception was Pink Rock :) ) that helped too.
I'll need a few more drives to further solidify my stance. @Lakshmi Narasimhan Good to know that the fans are helping. I will keep this in mind for future updates.
  • 2 months later...
  • 4 years later...
Hello friends! User from Costa Rica here, I own a 2018 Pajero 5 door, which is giving me a big headache. It overheats when going uphill, driving in D or Tiptronic does not make a difference. Driving 2WD or 4WD is the same result.
I notice when it starts overheating because the A/C starts getting hot, then the needle in the gauge goes over the middle line. When I start going downhill, it regulates and all fine.
I have already changed to a bigger radiator, new fan clutch, new thermostat.
I'm planning to do the bigger transmission oil cooler and aux fan for it, what do you recommend?
THANKS IN ADVANCE!
THANKS IN ADVANCE!
Hi @celoalvarado!
The overheating issue mentioned in this post above is related to the transmission overheating, while yours looks like the engine is overheating. This should definitely not happen on a Pajero.
You have approached it correctly by replacing the radiator, fan clutch, and thermostat. Another possibility could be perhaps the water pump that is not circulating the coolant properly.
I don't think a bigger transmission cooler or aux fan will help here. There seems to be a different reason why your engine is overheating.
I you changed the thermostat and radiator recently, are you sure there is no air left in the system? You can check in this way:
1. Start with engine cold → remove radiator cap
2. Fill coolant to the top of the radiator.
3. Start engine with radiator cap off.
4. Let it idle and watch for:
-Air bubbles coming out
-Coolant level dropping
Once:
Bubbles stop
Engine reaches operating temp
Coolant level stabilizes
5.Then put the cap back on securely.
