luis mantecon Posted May 4, 2021 Share Posted May 4, 2021 Thanks a lot @Hisham Masaadi will start with 11psi from this w.e 👍 1 1 Link to comment Share on other sites More sharing options...
Chris Wing Posted May 4, 2021 Share Posted May 4, 2021 23 minutes ago, luis mantecon said: I moved to the drive in the afternoon, I realized I couldn’t attend the one in the morning. By the way, as you both have BFGoodrich, also advise from other members is most than welcome, at which pressure do you drive in the desert? So far I used to drive at 10psi and I hadn’t had any problem until last week, and I am sure it was due to the valve was damaged ( both pop-ups were in the same wheel and @Bretterealized the valve has a small cut ). Do you drive at 10, 11 or 12? Mines are 285/70 R17. Thanks a lot !! Car is looking great! welcome to the BF Goodrich club I have steel wheels so I go down to 10/11. 2 1 Link to comment Share on other sites More sharing options...
