Lakshmi Narasimhan Posted May 19, 2021 Author Share Posted May 19, 2021 33 minutes ago, Srikumar said: What Fred is referring to is the transfer case. You are referring to the transmission overheating. Two different things I am not at all aware of the logic behind, what I assume is since it always checks where to supply more power it over heats (working some what similar to D mode). If the central diff is locked, its not overloaded. I cant think beyond this technically. Or might be some flaw in the factory design. But for sure ready to try different options and wanted to overcome overheating problem otherwise it takes away the fun and I start worrying about when I will encounter the problem. 1 Link to comment Share on other sites More sharing options...
Srikumar Posted May 19, 2021 Share Posted May 19, 2021 Are you still having ATF overheating after installing the fan and driving in tiptronic? Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted May 19, 2021 Author Share Posted May 19, 2021 1 minute ago, Srikumar said: Are you still having ATF overheating after installing the fan and driving in tiptronic? Yes, last Friday I tried driving on D had problem, and then i switched to tiptronic and climbed faya backside had problem. Thats why I started researching on this. Link to comment Share on other sites More sharing options...
GauravSoni Posted May 19, 2021 Share Posted May 19, 2021 @Lakshmi Narasimhan I drive with 4hlc since i started with intermediate drives and I feel the power on the long climbs…. 50/50 split works for me and I haven’t had the transmission heating issue for last 32 drives!!!! 2 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted May 19, 2021 Author Share Posted May 19, 2021 Just now, GauravSoni said: @Lakshmi Narasimhan I drive with 4hlc since i started with intermediate drives and I feel the power on the long climbs…. 50/50 split works for me and I haven’t had the transmission heating issue for last 32 drives!!!! Perfect, let me then try 1 Link to comment Share on other sites More sharing options...
GauravSoni Posted May 19, 2021 Share Posted May 19, 2021 (edited) 8 hours ago, Lakshmi Narasimhan said: Yes, last Friday I tried driving on D had problem, and then i switched to tiptronic and climbed faya backside had problem. Thats why I started researching on this. For straight climb at iftar bowl… 1st gear all the way… u need to pump! Edited May 19, 2021 by GauravSoni 1 2 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted May 30, 2021 Author Share Posted May 30, 2021 My transmission heating problem was due to some dirt stopping the fan from running, once that was fixed there is no more trans overheating problem. I also tried 4HLC which also worked in churned up sand very well. 1 1 Link to comment Share on other sites More sharing options...
