engine oil is below the safety line
a week back when the CE light came on i immediately stopped the car to check the basics and i noticed that the engine oil is below then the last line so i got it refilled and today same thing happened the oil was down. i cant seem to find the leak could there be another reason for this
If you have the noticeable smoke at exhaust that means engine oil leaking in fire chamber and getting burnt. This is because of piston rings is weak and need a change.
If no smoke then check the coolant has turned milky and looks like engine oil has been mixed with coolant??? Then engine head gasket is leaking.
