sidh Posted August 23, 2011 Share Posted August 23, 2011 One of the four wheels is jammed for some strange reason. i tried to tow the car as well and all the wheels moved except one. What should i do. Link to comment Share on other sites More sharing options...
rupert Posted August 26, 2011 Share Posted August 26, 2011 Check the brake pads and brake rotors, something must be terribly wrong there. If not then you should doubt the differential is exploded and its pinion is blocked with some metal part from inside. Change whole diff assembly. Big expense. Link to comment Share on other sites More sharing options...
