Chathura Posted August 30, 2023 Report Share Posted August 30, 2023 I have a issue, while driving car is switching off completely, when I switch on, engine starts and again switching off. It happens 8 time since last 7 months, nobody can find the fault and they telling many things time by time and temporally they fixing the car, Link to comment Share on other sites More sharing options...
Gaurav Posted August 30, 2023 Report Share Posted August 30, 2023 When car switches off, does it display any error messages on dashboard? Does it happen in stop and go traffic? With AC or without AC too? Is car regularly services? If not first doubt goes to spark plugs, faulty ICV, weak battery/alternator along with 10 other parts. Best is to get fully diagnose with OBD adapter when it switches off and which see fault code it register, so you can exactly pin-point the root cause. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Frederic Posted August 30, 2023 Report Share Posted August 30, 2023 Came across the following discussion: https://www.cruzetalk.com/threads/chevy-cruze-turns-off-while-driving.8869/page-2 one of the comments: “Two things to look into: the negative battery cable. It's a known issue in the Gen 1. The other one is the ignition relay. Cheap part ($8?), easy to change(in the fuse box) One person here found that was the problem in his car.” 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
