Fewbie Plus Exploration Drive (2 DAYS) - Ghayati to Arada - Abu Dhabi - 7-8 Feb 2026
Frederic
DRIVE DESCRIPTION-WHAT TO EXPECT
Venture beyond the edges of the map and immerse yourself in the vast silence of the Empty Quarter. Over two days we’ll carve our own route through majestic dunes, untouched desert plains, and landscapes that feel both ancient and otherworldly. This is not just a drive — it’s an exploration of one of the most remote and stunning environments on Earth.
We will navigate technical terrain, camp beneath star-filled skies, and share unforgettable moments around the fire. This journey blends challenge, camaraderie, and the profound beauty of the open desert.
If you’ve ever wanted to disconnect from the city, test your skills, and taste real exploration, this is the drive for you.
DRIVE PLANNING
  • Meetup at 8AM in Ghayati: https://maps.app.goo.gl/EmByh8zuVW6vtzULA
  • A Full Day Drive in varied terrain (dunes, plains).
  • Set up camp around 6PM in a quiet area and enjoy the evening together.
  • Second day drive until we reach the exit near Arada. (before noon hopefully).
Considering its seriousness to keep you and your vehicle safe, below rules apply:
ESSENTIAL PREPARATION:
  • Your car should be in 100% pristine working condition, so double or triple-check everything.
  • Full-size spare tire with a lug wrench to match your wheel nut size and its depth.
    • For aftermarket rims - Your lug wrench also needs to match the wheel nut depth.
  • As it's a long full-day drive, so catch up with enough sleep beforehand.
  • 5-10 liters of water per person.
  • Snacks for breakfast, lunch, dinner, and next day breakfast.
  • Keep your car as light as possible by packing what is truly essential.
  • Fully charged radio with spare battery and all other required off-road gears.
  • FULL MAIN TANK AND 1 JERRYCAN OF 20L.
DRIVE DETAILS:
Level:  Fewbie Plus and above
When:  7 and 8 Feb2026
Starting time: 8AM (SHARP - Without any exceptions)
Starting Point: https://maps.app.goo.gl/EmByh8zuVW6vtzULA
You can come early and camp at the same starting point if you like. (you can head inside on the same dirt track). Another option is overnight stay at the Western Hotel Al Ghayati.
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Approximate finish time: Between 11AM and 12AM the next day.
✅ RSVP:
  • Confirm your attendance by clicking on "GOING" in the Calendar Event. Your name will appear on the RSVP list.
  • If the RSVP is full, add yourself to the waitlist. As soon as a spot becomes available you will be moved automatically to the RSVP list.
  • The RSVP closes one day prior to the drive
  • Latecomers will be turned back (no exceptions)
  • No RSVP = No Drive
  • Please withdraw your RSVP if plans change
  • Repeated no-shows may result in 1-month suspension
RSVP HERE
  • WOW (+2) 1
  • Frederic changed the title to Fewbie Plus Exploration Drive (2 DAYS) - Al Ghayati to Arada - Abu Dhabi - 7-8 Feb 2026
  • Frederic changed the title to Fewbie Plus Exploration Drive (2 DAYS) - Ghayati to Arada - Abu Dhabi - 7-8 Feb 2026
7 minutes ago, Soap said:
I wanted to check if this drive would be family-friendly. Or, is it recommended to do it alone (no small kids)
Hi @Soap if your children can endure full day drives and have done it before, it would be ok. But it will be very taxing on them.
  • Thanks (+1) 2
@FredericYour drives honestly inspire me to sign up for more Fewbie drives so I can eventually join one of your FB Plus runs! 😄
Driving + camping is exactly my kind of thing — right in my sweet spot. Can’t wait to work my way up and be part of it! 🚙🏕️
Inshallah, will be joining one of these FB+ drives soon 🫡
You will be there very soon my friend! And as long as the weather permits i will try to squeeze in a few more adventures :)
12 hours ago, Soap said:
I think I will err on the safer side and pass.
Hopefully, sometime in near future, I will be able to join such drives
@Soap def take the kids on a couple of NB and FB drives first to get them used to it..  and going for a camp afterwards
mine have done quite a lot but still are absolutely exhuasted by the end of a 4hr drive and starting to get cranky 😅
  • Totally Agree (+2) 3
You definitely should!  Shared adventures are the best adventures after all, and the campfire atmosphere is great also.
Ask @khurramm as well, ever since a family drive in Lisali he has a  small co-driver that doesn’t want to miss any of the action.
  • Totally Agree (+2) 2
