surmaa Posted January 4, 2011 Share Posted January 4, 2011 the water pump of my windscreen has stopped working. how do i check for clog's please help Link to comment Share on other sites More sharing options...
ramesh Posted January 6, 2011 Share Posted January 6, 2011 It might have stopped working as windshield water jet hose which comes under the hood is disconnect due to opening or closing of hood or someone work there. Check those thin hoses first if its fitted properly. If it is, then insert safety pin in water jet holes as it might be blocked. If still cant get water change the water pump as i doubt you can clean it. Changing is the only way. Link to comment Share on other sites More sharing options...
