Specific batch problems?
nicholas
Thanks Robert. I'm trying to compare some part if it is cheaper just to buy on e-bay & just get them fix here with just a labor cost but most of the small maintenance part, it is better off to buy it here, but some major part for example lower arm or front knuckle you can get it cheaper on-line.
Sure you can order online but you will always have the risk of not matching to GCC spec car even if you match the product code and ID completely. Still it's worth a shot if it saves over 50%, why not.
