humair Posted March 22, 2014 Share Posted March 22, 2014 Hey people. can anyone tell me how to check the cooling system if it is holding pressure or not? Link to comment Share on other sites More sharing options...
amitaj Posted March 23, 2014 Share Posted March 23, 2014 Very interesting question. i know one method. To check the pressure of the cooling system, tighten up the radiator cap properly when the cooling system is top off. Then start the engine. Switch on the air condition and go for a short drive. After the drive, check all the common places where coolant leak can be noticed. Water pump, radiator, freeze plug and hoses. If there is no leak, then the cooling system of your car is holding proper pressure. Link to comment Share on other sites More sharing options...
humair Posted March 23, 2014 Author Share Posted March 23, 2014 Thank you so much Amit. I was really helpful. I will definitely try this and reply you back. Also, one more question was there is my mind. Is there any other method as well to test the same? Link to comment Share on other sites More sharing options...
