JeepDxb Posted August 27, 2011 Share Posted August 27, 2011 Jeep commonly used terms Encyclopedia 45RFE-automatic transmission in the V8 WJ 8.25-Chrysler 8.25" axle found in XJ rears ARB-A company based in Australia that produces popular winch-compatible bull bars and differential air lockers. AT (A/T)-all terrain (all terrain tread) tire ATF-Automatic Transmission Fluid AW4-the automatic transmission used on the XJ since 1987 AX15-5 speed manual stick in a pre-99 6 cylinder TJ AX5-5 speed manual stick in a pre-99 4 cylinder TJ BB-Budget Boost. An inexpensive, popular 2" lift used by many Jeepers. BL-body lift BS or Back Spacing. backspacing, distnace from the mounting flange of a wheel to the inner edge (rim) of the wheel. i.e. larger BS will cause the wheel to sit "into the fender" more, smaller BS will cause the wheel to "stick out" more. Absolutely necessary to determine proper wheel and tire combination CAT-catayltic converter CJ-Jeep Wrangler's Older Model Years. "Civilian Jeep" CJ-2A-Civilian version of the MB, split windshield CJ-3A-Updated version, single pane windshield CJ-3B-High hood version of 3A to fit larger engine CJ-5-Early years were 81" wheelbase, later years were ~84". Built until 1983. CJ-6-Stretch version of CJ-5, 101" wheelbase CJ-7-smilar to late CJ-5, but with ~94" wheelbase. Built until 1986. CJ-8-Scrambler Pickup, stretch version of the CJ-7, 104" wheelbase. CJ-10-Heavy Duty Truck. D30 (D30r)-(DANA30) D44 (D44i)-iron Dana 44 axle (TJs) D44a(D44) but with aluminum housing (V8 ZJs and WJs) D60-(DANA60) DANA30 (DANA30r)-front axle (r = reverse cut) All modern Jeeps DANA35C-axle (YJs, ZJ, WJs, TJs) DANA60-axle (very strong) DC-Daimer Chrysler DW-death wobble. Side to side movement of the front axle that causes the Jeep to shake violently. Most common on lifted ZJ's before a wheel alignment has been done. Can be caused by worn steering stabilizer, improper wheel alignment, or worn front suspension components. ECU-Engine Control Unit (same as PCM). Very popular mod. Common one made by Mopar. EFI-electronic fuel injection F2R-front to rear swap lift FC150/170-Forward Control Cabover trucks FM-FlowMaster muffler FSJ-Full Size Jeep (SJ's and J-trucks). FSM-field service manual GC-Grand Cherokee GPW-Willy MB built by Ford HO-High Output. New engine option for WJs HP-high pinion. Usually accompanied by RC gears - the pinion enters the differential higher, which allows for better driveline angles. IAC-idle air controller ICE-This flashes on overhead display when the temperature is below 32 degrees IFS-independent front suspension IRS-independent rear suspension JGC-Jeep Grand Cherokee JU-Jeeps Unlimited K&N FIPK-Fuel Injection Performance Kit refers to an air intake kit from K&N KJ-Jeep Liberty All Model Years LA-Long arm LCA-lower control arm LSD-limited slip differential LWB-long wheel base MAF-mass air flow sensor. Measures airflow coming into your engine in front of the throttle body. Uses a form of resistor that is cooled by the air passing by it and mathematically determines the "mass" of the air coming into the engine. These are traditionally bottle necks for heavy breathing engines as they often have a screen in them to protect the measuring element. There are many different designs and high performance large capacity ones out there. MAP-manfold absolute pressure. A sensor that tells the computer how much air is flowing into your engine. Eliminates the need for a MAF sensor but is less responsive than one. MT (M/T)-Mud terrain (mud tread) tire NP231-Command-trac transfer case (2H, 4H, N, 4L) NP242-Selec-trac transfer case (2H, 4PT, 4FT, N, 4L) NP249-Quadra-trac transfer case (4H, N, 4L) NV3550-5 speed manual stick in a post-99 6 cylinder TJ NVRnoise vibration harsness OBA-on board air OBC-on board computer OBDII-on board-diagnostics OEM-Original Equipment (standard equipment on our vehicles like it came from the factory) OHC-Overhead console OME-A manufacturer of small lifts and shocks and steering stabilizers. Their SD40 steering stabilizer is very popular. PCM-Performance Control Module (same as ECU) PSI-pounds per square inch QD-Quadradrive QT-Quadra-Trac RA-Road Armor RC-reverse cut. This is a ring and pinion set with the helix on the gears cut in the opposite direction to normal. It allows the pinion to enter the differential higher up in the casing, and, when used in the front differential, makes use of the stronger side of the ring gear when moving forward. RE-Rubicon Express SAS-solid axle swap. Taking out the crappy IFS (ala Liberty) and replacing with something you can 'wheel on. SFA-solid front axle SOA-spring over axle. A popular conversion for Jeeps with leaf springs. You take the spring from under the axle, and remount it on top. SRA-solid rear axle SWB-short wheel base SYE-slip yoke eliminator. A kit used mostly in 231 transfer cases to shorten the rear output shaft TB-throttle body TB-track bar. that positions and centers the axle (front or rear) relative to the body. TC-transfer case TC-torque converter Tera-Teraflex. Maker of Jeep products including lifts TJ-Jeep Wrangler's Model Years 1997-Present TPS-throttle position sensor TQ-torque converter TR-trail ready TSB-technical service bulleten TV Cable-Throttle valve cable (controls shift points) UCA-upper control arm VIC-vehicle information center VC-vicuous coupling. Method of coupling front and rear driveshafts together in 249 transfercase while in highrange and offers differentiation between the two. 96-98 models bypass this and lock in low range WJ-Jeep Grand Cherokee's Model Years 1999-Present XC-transfer case XJ-Jeep Cherokee's 1984 - Present YJ-Wrangler 1987 - 1995. Exact same wheelbase as CJ-7... square headlights ZJ-Jeep Grand Cherokee's Model Years 1993-1998 Link to comment Share on other sites More sharing options...
