Jocreative Posted May 9, 2012 Share Posted May 9, 2012 Actually on the roads, if you notice all the cars that have a brake light issue, Its always the rear LEFT!! Why is it that the LEFT is the first one to be attacked everytime! I did some searching and found that this could be a common issue. Although I am still not clear on the solution. The bulbs are working fine. They work for headlight beam indicators, turn signal indicators. Only when the brakes are pressed, the left one fails to glow. I even changed the tail light assemblies. Could this be a fuse issue? Or a Short? Best way to detect it? Link to comment Share on other sites More sharing options...
khandelwal Posted August 23, 2012 Share Posted August 23, 2012 it should be a fuse or brake sensors if its not the blubs. Link to comment Share on other sites More sharing options...
Jocreative Posted August 23, 2012 Author Share Posted August 23, 2012 Hello Mace, thanks for the reply. could you guide me to the fuse for brake lights? Link to comment Share on other sites More sharing options...
