khandelwal Posted March 7, 2014 Share Posted March 7, 2014 How to check bad wiring connections in a car? Link to comment Share on other sites More sharing options...
khandelwal Posted March 10, 2014 Author Share Posted March 10, 2014 To check the bad wiring connection, one can do voltage drop test. To do a voltage drop test, one needs to create a load in the circuit that is to be tested. Then use DVM (digital volt meter) to take the readings of the circuit. When the connection is good between the voltmeter and circuit, you will get some readings on the meter. If the readings shows very little or no voltage, then the wiring is perfect in the car. But if you experience high voltage, then the wiring in the car is bad. If you don't know how to do it, you can directly go to a professional garage, they can do it easily. Link to comment Share on other sites More sharing options...
khandelwal Posted March 18, 2014 Author Share Posted March 18, 2014 Can we check the bad wiring with the light test as well? Link to comment Share on other sites More sharing options...
khandelwal Posted March 19, 2014 Author Share Posted March 19, 2014 Yes you can. You need to place the light test tool on the wiring. If the the tool blows, it means the wiring is fine. If the tool doesnt blow, it means the wiring is bad. Link to comment Share on other sites More sharing options...
