luluaa Posted April 26, 2011 Share Posted April 26, 2011 my m20 is going off track when speeding do i need to check the tiers or there is something else that needs a check thanks Link to comment Share on other sites More sharing options...
trueguy Posted May 8, 2011 Share Posted May 8, 2011 Check the stability program is on and working, if its not it will display the error message as its quite major safety issue. If you mean its changing track on high speed, then its a wheel alignment issue. Emarat fix plus can fix it in 150 dhs. Link to comment Share on other sites More sharing options...
