jack Posted May 24, 2011 Share Posted May 24, 2011 when replacing my X5 2005 shocks the suspension leveling light came up which the dealer fixed twice and replaced the sensor once but the light would still come up. the shocks and compressor are working fine but the warning light is very upsetting. is there another way to fix it i am fed up with the dealers now? thanks Link to comment Share on other sites More sharing options...
bimmerguydxb Posted May 25, 2011 Share Posted May 25, 2011 Do the following proper diagnostic to find the real culprit. Check all the air bladders for leaks or major small small cracks at the base of bladder. These ar bladder have a life of three years or 50k km at max. If you haven't change them please do so. As these minor invisible leaks makes most of the problem and vehicle keep getting leveled and inflated and then light throws up all the time. Also check the valve leaking (if any). Also check all sensors are reading fine with OBD II diagnostic tool. Link to comment Share on other sites More sharing options...
