leaking differential after axel change
i had to get my front axel changed and soon after that replacement the differential began to leak from the gasket. the mechanic said that these tow thing are nowhere connected but i beg to differ.
i want a second advise please.
thank you
I hope you meant for front differential right???? If its rear diff leaking, its not related but if id front for sure its related.
Ask mechanic how he can change the axle without removing the diff. And if he remove the diff then he has removed the differential gasket and re fixed it too. As it wasn't fixed properly thats why its leaking and its his problem for sure of not doing job properly at first time.
Threat him to call police or else fix the car. As he need to learn lesson of being more professional before taking up another job and pay for his mistakes.
  • 2 weeks later...
