ramankher Posted October 30, 2011 Share Posted October 30, 2011 the rear of my RR was banged with a divider and has been leaking something but dont know what? How can i find out what is leaking? Link to comment Share on other sites More sharing options...
pushkar Posted October 31, 2011 Share Posted October 31, 2011 It can be brake oil, engine oil, gear oil, transmission oil or coolant. Link to comment Share on other sites More sharing options...
bmwdoc Posted December 8, 2011 Share Posted December 8, 2011 It can be brake oil, engine oil, gear oil, transmission oil or coolant. it could also be fuel, this is easy to check....Light a match and throw it in the wet patch, if you burn your eye brows off and the car catched fire you will know it was fuel. failing that take it to a garage. Link to comment Share on other sites More sharing options...
qvzd02 Posted December 14, 2011 Share Posted December 14, 2011 It sounds like you do need a new oil pressure sending unit, it could have been banged around while the other repairs were made, or it could be that the connector on the end of it is just loose. Have them check to be sure they put the wiring on the sensor and it is on there tight. If the wiring is tight, then the sensor will need to be replaced. Link to comment Share on other sites More sharing options...
bmwdoc Posted December 14, 2011 Share Posted December 14, 2011 since when has an oil pressure switch been at the back of a car? i think you mean Fuel sender unit but this is inside the fuel tank and the fuel tank would be more likely to break first, you do however have a fuel filter under the back and could also be that! i still say take it to a garage! Link to comment Share on other sites More sharing options...
