xeus Posted January 26, 2011 Report Share Posted January 26, 2011 i am the owner of 1999 LS and i recently got the break pads changed but the brake wear light wont go off. how can i switch it off. thanks Link to comment Share on other sites More sharing options...
seddiqi Posted January 26, 2011 Report Share Posted January 26, 2011 You also need to put brake light sensor in the pad, so that light will go off. Its cheap fix. Link to comment Share on other sites More sharing options...
LS430'06 Posted January 27, 2011 Report Share Posted January 27, 2011 You will have to replace the brake pad sensor, see where the brakes were really worn out and then replace one of them. You only have two on the car and on the passengers side. One in front and one in the back. Good luck. Link to comment Share on other sites More sharing options...
xeus Posted January 28, 2011 Author Report Share Posted January 28, 2011 Thanks LS430'06 and Sediqi. I really appreciate ur help. Cheers. Link to comment Share on other sites More sharing options...
