shaun Posted June 20, 2012 Report Share Posted June 20, 2012 CAN ANYONE TELL ME WHAT DOES TAIL LAMP FAILURE MEANS.... RECENTLY I NOTICED THAT MY NUMBER PLATE LIGHTS WERE NOT WORKING.. SO I INSTALLED NEW PLATE NUMBER LIGHTS .. BUT STILL IT IS SHOWING THE SAME ERROR.. WHEN I START THE CAR THEN THERE IS NO TAIL LAMP FAILURE .. BUT AS I CHANGE THE GEAR OR PRESS THE BRAKES , IT SHOWS TAIL LAMP FAILURE.. THEN IT DOESNT GOES UNTIL I SWITCH OFF THE ENGINE.... PLEASE HELP ME ... Link to comment Share on other sites More sharing options...
speedy Posted June 27, 2012 Report Share Posted June 27, 2012 did you check the fuse if they are working. and when you star the car are the back lights on ( not brake lights but the ones that are above them). check these two things and i am sure you will find your answer. Link to comment Share on other sites More sharing options...
lawrence Posted September 13, 2012 Report Share Posted September 13, 2012 CAN ANYONE TELL ME WHAT DOES TAIL LAMP FAILURE MEANS.... RECENTLY I NOTICED THAT MY NUMBER PLATE LIGHTS WERE NOT WORKING.. SO I INSTALLED NEW PLATE NUMBER LIGHTS .. BUT STILL IT IS SHOWING THE SAME ERROR.. WHEN I START THE CAR THEN THERE IS NO TAIL LAMP FAILURE .. BUT AS I CHANGE THE GEAR OR PRESS THE BRAKES , IT SHOWS TAIL LAMP FAILURE.. THEN IT DOESNT GOES UNTIL I SWITCH OFF THE ENGINE.... PLEASE HELP ME ... did you find the failure ?? Link to comment Share on other sites More sharing options...
shaun Posted November 20, 2012 Author Report Share Posted November 20, 2012 I have the same problem... Initially my plate number lights were not working but even after installing them i have the same problem. One of my friends told me that there might be voltage difference between the lights you bought and the ones that are original.. probably i bought the Chinese ones. Link to comment Share on other sites More sharing options...
