zubain Posted January 7, 2011 Share Posted January 7, 2011 the fuel is not reaching the engine.it will only run if the fuel is externally introduced to intake. is this the problem with the fuel pump,fuel filter or the throttle body any advice is welcome Link to comment Share on other sites More sharing options...
alexd Posted January 10, 2011 Share Posted January 10, 2011 change fuel filter, as its cheaper fix. then fuel pump. It cant be throttle body (90%) Link to comment Share on other sites More sharing options...
