MercedesDubai Posted August 27, 2011 Share Posted August 27, 2011 Mercedes-Benz Scheduled Maintenance Procedures Rotate and Inspect tires Inspect Brake system Inspect Exterior lamps Inspect Fluid levels Inspect Interior switches Inspect Steering & suspension Inspect Transmission fluid Inspect/Adjust Fluid levels Inspect/Adjust Parking brake Inspect/Adjust Throttle Linkage Inspect/Adjust Tires (air pressure) Inspect/Adjust Windshield washer nozzles Inspect/Lubricate Door hinges & latches Inspect/Lubricate Hood locks Inspect/Lubricate Sunroof glides Inspect/Read Fault codes Inspect/Reset Service indicator light Inspect/Service Brake pads, calipers & rotors Inspect/Service Climate control system Inspect/Service Exhaust system Inspect/Service Exterior lamps Inspect/Service Fluid leaks Inspect/Service Interior lamps Inspect/Service Steering & suspension Inspect/Service Windshield wipers & washer Inspect/Tighten Drive belts Replace Air filter Replace Brake fluid Replace Cabin air filter Replace Coolant Replace Engine oil & filter Replace Fuel filter Replace Spark plugs Link to comment Share on other sites More sharing options...
