NissanDxb Posted August 28, 2011 Share Posted August 28, 2011 Nissan Maintenance Procedures - Common Additional Services Nissan Air Filter Replacement The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms. Nissan Automatic Transmission Fluid Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms. Nissan Automatic Transmission Fluid/Filter Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms. Nissan Coolant Replacement/Flush Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms. Nissan Drive Belt(s) Replacement Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms. Nissan Manual Transmission Fluid Change The Manual Transmission fluid breaks down and becomes contaminated with moisture over time and can lead to transmission damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Nissan Spark Plug Replacement Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval. Link to comment Share on other sites More sharing options...
