What is the function of o2 sensor?
tobye
My mechanic says that the O2 sensors on the exhaust pipe need to be changed but i dont know why when i just went for getting the fuel filter changed as the car was giving bad fuel efficiency . My question is if i change the o2 sensors do all of them get changed and what are their functions.
the sensor makes sure that the air and fuel is mixed in correct ratio if the air is more then the fuel quality will decrease and if the air is less then the fuel will leave residue that will harm the car again and exhaust too.
  • 2 months later...
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
The thread has been created long ago, but I will give my inputs on this anyway. If there is no Check Engine Light (CEL) then the O2 sensors are probably working fine. A CEL doesnt always mean that O2 sensors need to be changed. You should hook up a diagnostic tool to the OBDII port and get the DTCs and then troubleshoot and solve the error. Would have saved you $$$.
