syedshah201 Posted September 13, 2011 Report Share Posted September 13, 2011 when i start my car and need to speed up as the car reach 50km/h the RPM suddenly goes to 50 and after that car back to normal and also my car is heating up as i think bc the heat radiator show above 90 but if it goes above 90 if you off the AC the heat bar goes down... any help will be appreciated. My car is 307, (Model 2004) only One hundered thousand done. Link to comment Share on other sites More sharing options...
junaidh Posted September 15, 2011 Report Share Posted September 15, 2011 Hi Syed, it makes me feel two different issues. RPM jumping is may be cause of loose air flow meter socket or AFM is bad or even bigger gear is slipping and need gear oil change (which i doubt) or whole gear rebuild (worst case). Second issue of overheating, it may be coz of radiator is choked, AC fan is not working as when u switch off AC it comes to normal. So get the AC fan check at first and see if your overheating get fixed. Once car is at normal temp see if RPM stop jumping. May be its co-related, but i really doubt as i am not sure. So get the root problem sorted first and spend less. Good luck. Link to comment Share on other sites More sharing options...
syedshah201 Posted September 18, 2011 Author Report Share Posted September 18, 2011 Thank you for your concern, i have recently changed the gear oil and filter but the problem remains still. Secondly overheating, it only goes to 95 and stops there no matter how long you drive, please advise is it normal or it should not go above 90... Thanks Link to comment Share on other sites More sharing options...
207_gti Posted October 15, 2011 Report Share Posted October 15, 2011 the temp should stay just below 90. the cause of this may be the waterpump, a racked radiator, or simply that the coolant or oil levels are too low. as for the rpm issue, yes that could be that the MAF sensor is not working properly, a loose o2 sensor, faulty coil pack, or even timing...although with a fault coil pack or timing issue u should feel the car jerk when it drops the rpm like that ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
