Porsche Maintenance Procedures - Common Additional Services
Porsche Air Filter Replacement
The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms.
Porsche Automatic Transmission Fluid Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms.
Porsche Cabin Air Filter Replacement
Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms.
Porsche Differential Fluid Replacement - Front
Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Porsche Differential Fluid Replacement - Rear
Porsche Drive Belt(s) Replacement
Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms.
  • 11 months later...
  • 6 months later...
For the Cayenne the recommended additional maintenance services are:
Replacing spark plugs
Replace spark plugs in Cayenne Turbo every 60,000 km or every 4 years
Replace spark plugs in Cayenne S every 90,000 km or every 4 years
Additional maintenance every 120,000 km
Air cleaner: replace filter element
Additional maintenance every 240,000 km or every 16 years
All-wheel final drive: replace oil
Rear final drive: replace oil
Transfer box: replace oil
Tiptronic transmission: change ATF and ATF filter
Every 2 years
Change brake fluid (use only original Porsche brake fluid)
Maintenance every 4 years
Check tyre pressure monitoring system battery
Replace tyre sealant
Maintenance after 10 then every 2 years
Inspect airbag system (see Major maintenance)
  • Carnity unpinned this topic
