Sfernandes Posted February 20, 2011 Share Posted February 20, 2011 how can i replace the ignition coil in a 2000 camry Link to comment Share on other sites More sharing options...
dubaiguy Posted February 25, 2011 Share Posted February 25, 2011 1.Disconnect your battery by removing the ground cable wire from the terminal. For additional safety, set your emergency brake. 2. Use a wrench or a socket to loosen the two nuts and clips on the cylinder head cover. This exposes the Camry ignition coil. 3.Remove the ignition coil connectors. You should find four of these. 4.Pull up on the ignition coil to dislodge it from the cylinder head. You may want to twist slightly to help break the seal between the cylinder head and the ignition coil. 5. Install the new Camry ignition coil. You can use a stock replacement or a universal ignition coil. Be sure the ignition coil works with your type of engine--there's a variety of universal ignition coils on the market. 6. Tighten the connectors, nuts and clips in place. 7. Reconnect the battery. Link to comment Share on other sites More sharing options...
