giridar Posted March 16, 2011 Report Share Posted March 16, 2011 there was a leak below my car, when checking i found that the leak was from timing belt housing but not sure how to get it repaired so i went to the mechanic and he said that the timing belt needs to be changed now what dose a belt have to do with the leak was out of my head need a second opinion please Link to comment Share on other sites More sharing options...
Amalik Posted March 20, 2011 Report Share Posted March 20, 2011 Go get second opinion, timing belt never dies and result in leaking. It has slipping and starting issue and if its already bad your car wont start. Mechanic need some work so he is changing timing belt, most expensive maintenance in whole car. All it cud be engine oil sump seal is gone and he is showing you different story. Link to comment Share on other sites More sharing options...
sabih Posted January 10, 2013 Report Share Posted January 10, 2013 Guys... how did it fixed finally? i experienced same problem yest... now i m in a fix what to do Link to comment Share on other sites More sharing options...
jjohn Posted January 20, 2013 Report Share Posted January 20, 2013 hey how was it fixed? Link to comment Share on other sites More sharing options...
giridar Posted March 14, 2013 Author Report Share Posted March 14, 2013 it was the radiator leaking and that was the second mechanic who said this so fixed it. Link to comment Share on other sites More sharing options...
