baron Posted July 8, 2011 Share Posted July 8, 2011 the Air Bag Warning light is on and i would like to switch it off. How Link to comment Share on other sites More sharing options...
farzaank Posted July 10, 2011 Share Posted July 10, 2011 get a code from the VW approved workshop as they will have the equipment to read the stored diagnostic fault codes to determine which circuit has the problem and then it can be repaired it is advisable to get the air bag checked after every 2 to 3 years Link to comment Share on other sites More sharing options...
baron Posted July 15, 2011 Author Share Posted July 15, 2011 will keep that in mind thank you Link to comment Share on other sites More sharing options...
Pramod VeeRow6 Posted July 16, 2011 Share Posted July 16, 2011 A diagnostic readout will have to be done to confirm which airbag is giving the fault. After that it needs to be checked to confirm whether its a wiring fault or the unit itself. Link to comment Share on other sites More sharing options...
