adil Posted July 15, 2014 Share Posted July 15, 2014 Is it possible to repair the horn of a car without under supervision of any expert? Link to comment Share on other sites More sharing options...
lonely Posted July 30, 2014 Share Posted July 30, 2014 The horn completely stopped or the horn volume is really low? If the volume is low, then you have to open the hood and check for the horn connector near the radiator and fix the connection problem. If the horn is not working completely, it means the fuse is gone. You need to fix the fuse. Link to comment Share on other sites More sharing options...
ghassank Posted April 30, 2015 Share Posted April 30, 2015 Good advice lonely. I had this problem two years ago - my horn completely start working although I rarely use it. I had to fix it at a car repair shop. Link to comment Share on other sites More sharing options...
