naeem Posted November 23, 2016 Report Share Posted November 23, 2016 sir i need my car to repair the problem is .it is taken to mush long to start when it start after some time the engine is off or rpm is up or down so i again start the engine it start but less accelerator plz tell me what a problem in my car my car is nissan sunny 2004 eng 1.3 thanks 0554348652 Link to comment Share on other sites More sharing options...
ameen Posted November 23, 2016 Report Share Posted November 23, 2016 Sounds like your car need a proper service and inspection of all spark plugs and coils. Weaker spark or irregular spark throws difficulty in starting and hesitation what you mention. Hope your engine oil is changed on time like every 5000 kms, if not I suspect that's why car shut off if engine oil is not providing enough lubrication. Link to comment Share on other sites More sharing options...
desertdude Posted November 23, 2016 Report Share Posted November 23, 2016 I think a 04 is a carburetor fuel system, not sure though, sounds like that needs a tuning, of the usually spark plugs and wires is also the obvious thing to look at Link to comment Share on other sites More sharing options...
naeem Posted November 24, 2016 Author Report Share Posted November 24, 2016 17 hours ago, naeem said: sir i need my car to repair the problem is .it is taken to mush long to start when it start after some time the engine is off or rpm is up or down so i again start the engine it start but less accelerator plz tell me what a problem in my car my car is nissan sunny 2004 .sir i have change my car spark plug and coil and car eng oil is good plz advice me eng 1.3 thanks 0554348652 Link to comment Share on other sites More sharing options...
naeem Posted November 24, 2016 Author Report Share Posted November 24, 2016 1 hour ago, naeem said: sir i need my car to repair the problem is .it is taken to mush long to start when it start after some time the engine is off or rpm is up or down so i again start the engine it start but less accelerator plz tell me what a problem in my car my car is nissan sunny 2004 .sir i have change my car spark plug and coil and car eng oil is good plz advice me eng 1.3 1 hour ago, naeem said: Link to comment Share on other sites More sharing options...
naeem Posted November 24, 2016 Author Report Share Posted November 24, 2016 sir i need my car to repair the problem is .it is taken to mush long to start when it start after some time the engine is off or rpm is up or down so i again start the engine it start but less accelerator plz tell me what a problem in my car my car is nissan sunny 2004 .sir i have change my car spark plug and coil and car eng oil is good plz advice me eng 1.3 Link to comment Share on other sites More sharing options...
Barry Posted November 24, 2016 Report Share Posted November 24, 2016 @desertdude are you sure? I haven't seen a carb as standard on anything since the early 90s. If anything, it's possible to be SPI which kinda looks like a carb but I'd put money on it being MPI. @naeem you need to check the basic things first like spark plugs and air filter. It could also be a problem with a weak fuel pump. There are a lot of possible answers but the best one is to find a good mechanic and take the car to him. Link to comment Share on other sites More sharing options...
desertdude Posted November 24, 2016 Report Share Posted November 24, 2016 No I'm not that's why I exactly said, I'm not sure in my post. Link to comment Share on other sites More sharing options...
desertdude Posted November 24, 2016 Report Share Posted November 24, 2016 P.S :The Y61 Patrol 2dr variant used a 4.5 I6 carb engine well into the 2000s Link to comment Share on other sites More sharing options...
naeem Posted November 26, 2016 Author Report Share Posted November 26, 2016 On 11/24/2016 at 8:26 PM, Barry said: @desertdude are you sure? I haven't seen a carb as standard on anything since the early 90s. If anything, it's possible to be SPI which kinda looks like a carb but I'd put money on it being MPI. @naeem you need to check the basic things first like spark plugs and air filter. It could also be a problem with a weak fuel pump. There are a lot of possible answers but the best one is to find a good mechanic and take the car to him. sir good moring .yah i thing so bez i take long start ans in the signal when the race is down eng is off and hard to start the engine Link to comment Share on other sites More sharing options...
