when to replace the tires
Traction is a term used to describe the tires performance on wet roads. When tires can divert the direction of water beneath them is knows as traction. Such tires help in lesser hydroplaning and smooth drive on a rainy day. It’s really important for tires to perform so on wet roads, otherwise the car may slip in the rain.
  • 9 months later...
From the moment you notice that the distance your car needs in order to make full stop has increased, you should definitely check and replace your tires. You can also use the experience of your auto repair shop and ask them whether you should change them whenever you are there.
