deand Posted January 3, 2015 Report Share Posted January 3, 2015 When and how to replace the heater core? Link to comment Share on other sites More sharing options...
ian Posted January 7, 2015 Report Share Posted January 7, 2015 When to replace? Its simple. Replace it when its broken. How to replace? Follow the following steps: Before replacing it, remove the negative terminal of the battery At first, raise your vehicle from the front Then you need to drain the coolant and antifreeze from the radiator Now remove the hoses from the heater core You can lower your car back to the normal position. Now locate the heater cores and remove the mounting clamps of the same. Remove the heater core and dry the carpeting by side. You can now install the new heater core as per guided and suggested by your dealer or as per mentioned in the car manual. That's it! Link to comment Share on other sites More sharing options...
