2008 Nissan Sentra
I have an 08 nissan sentra special edition.
Whenever I try to start the engine it always turns then won't start. It usually takes one
of two turns of the key to get it started.This doesn't happen only when I first crank it up in the morning and after I get gas. Any ideas?
  • 3 years later...
Sentras have a common problem with the fuel pump nozzle it just cracks when it gets old you should also be having increased fuel consumption due to the leaking joint...my advice would be to get the seat removed and open the pump hatch and watch for leakage signs
