Vibration from rear end
The Tyres might have a pouting bubble or the shaft's cross or the bearing in center of shaft has gone bad then in that case you have to change the shaft as those center bearing in most cases can't be changed...for more clear diagnosis it has to be taken to the workshop....
Edited by shadow79
More information
Swap the front and rear wheels (assuming they’re not staggered) and see if the vibration moves to the front. If it does, it’s a wheel, tyre or balancing issue. If not, you need to dig deeper.
