how often the enginge oil needs to be changed
Engine oil change is ideally related to kms. If you put mineral oil 20w50 its 3k kms, if you put semi synthetic oil 10w40 its 5k - 7k, If you put fully synthetic oil its 10k - 12k kms.
Color is last indicator to consider, but not the first one to consider. I change per km not with color. why risk it, oil is very cheap in this country so change often is better.
