Modifying a 2004 Manual Pathfinder R50
Fuad
11 minutes ago, Frederic said:
Congrats with the ride buddy. Come and join us for a number of drives and then start setting up your plan. First stick with the basics of getting the car FULL inspected: battery, all fluids, compression, cooling system, etc.... You might need to shell out a few thousands to get that part in 100% condition.
Insepected everything, and replaced few bushes and all are good to go. Was previously well maintained by last owner.
24 minutes ago, Srikumar said:
So then why change a working formula?
Yeah. Thinking u r absolutely right.  Looking forward to follow your suggestion.
thanks @Srikumar
Congratulations. Just for information can you please share how much you paid for it. What is the odo reading?
40 minutes ago, Javier M said:
  • Headers
  • Lift kit I think OME sells 1.75" springs for pathfinders
  • better recovery points
  • bash plate
  • cold air intake
  • I would remove the side steps - they reduce the ground clearance
I dont wanna remove side steps as tbh i suffered a lot when i removed side steps on my pajero.
thanks @Srikumar
And I also think you need to start hitting the dunes quickly.
Has been hitting dunes for past few weeks all around alain + sweihan.
will soon join carnity for a spin 😉
al yahar has some beautiful dunes ,we should try it some day 😉
First order of business, do a full and complete service. Change all fluids and filters.
Engine oil and filter
Transmission oil
Coolant
Flush and refill new Brake and Clutch oil
Transfer case oil
Front and rear diff oil
Check and test engine cooling system.
Hoses and belts
Plugs and wires
Grease all joints and shafts where applicable
So you have a good worry and problem free season
  • Totally Agree (+2) 4
Congrats @Fuad I guess everybody got to it before I could even think of answering any questions. You've seen my Pathy I am not much of a mod guy, but I think ground clearance could be an issue at Fewbie+ level and above. But first you need to feel the need for the mod and be specific so we can all help in making your rife closer to what you need out of it.
@Rahimdad you are my Guru. definetly i admire your skills and pathy. Thank you for guiding on acquiring a pathy of my on. Will eventually spin my vehicle and keep updated with all the mods n this thread.
will update the specs soon after this weekend.
  • Well Done (+2) 2
On 9/23/2019 at 2:29 PM, Fuad said:
I recently bought a 3.5 2004 manual pathfinder which is meant to use only for weekend drives. I would like to have experts valuable inputs
-on building machine
-things to be taken care of
-selection of materials
-Reliability of materials
Attaching photos.
waiting for inputs
Congratulations Fuad, I'm going to miss your Paj during the drives 😛
Enjoy and drive safe, See you soon !
