Thomas Varghese Posted March 22, 2021 Share Posted March 22, 2021 19 hours ago, Kalahari said: @Thomas Varghese the first indication was steering wheel controls for radio stopped working, then the horn. I tried replacing with used one, but it was not 100% same spec (so ABS kicked in every time I made a turn :-)). So put old one back and ordered new part from Nissan. Need to replace new one now. TC (traction control) is issue related to kill switch only. Worked 100% (with far more manual power when tackling steep dunes), but suddenly stopped working recently (despite kill switch seemingly doing its job). I checked with my mechanic and you are right. This issue is because the clock spring or the spiral cable is faulty. I only put the issue I faced with my Altima as it was also facing same gear issues because the speed sensor inside the transmission went faulty. It had difficulty in coming back to 1st gear sometimes and the car could barely climb up an incline or accelerate from a traffic stop. The OBD scanner was throwing the code for bad speed sensor inside the transmission. 1 Link to comment Share on other sites More sharing options...
